Radome location
Marine radars use one of two frequency bands — X-band (9000 MHz) or S-band (3000 Mhz). Because the shorter 3-cm (about one-inch) wavelength allows the use of a smaller and lighter antenna, most small-boat radars operate on the X-band. Both band systems will detect and display precipitation, but S-band units will do a better job of penetrating rain to spot targets on the other side. The X-band’s shorter wavelength will suffer greater attenuation when passing through precipitation, reducing the amount of reflected energy received from objects obscured by heavy precipitation.
The RADAR HORIZON (in nautical miles) is 1.22 times the square root of the scanner height (in feet), while the Visible Horizon in nautical miles is 1.169 (usually rounded to 1.17) times the square root of the height of eye in feet. The maximum radar range is determined by the height of the scanner, and the power output of the transceiver.
ie:
A radar antenna mounted at 12'' above the water will “see” about 4.23 nm. If the target was also 12'' high, the radar would see it at about 8.45 nm (4.2262 + 4.2262).
Range = 1.22 x sq. rt. 12 = 1.22 x 3.454 = 4.2262
The shape or angular dimensions of the beam also play an important performance role. The vertical angle of the beam emitted from the scanner is typically 15 to 30 degrees (equally divided by the horizontal axis of the mount). For a 25-degree beam width, 12.5 degrees of the beam will be below the horizontal axis, if the scanner is mounted level with the water. The horizontal beam width varies from 0.5 degrees for larger installations (largely dependant upon antenna length) to five degrees for smaller designs. Three to five degrees is typical for small-boat radars. In general, larger scanners have narrower beam angles, and more accurate bearing resolution. Radar is generally more accurate in determining target Range, than Bearing.
The horizontal beam width of a radar determines the bearing resolution (the radar’s ability to discriminate between multiple targets that are close together). If the beam is wide enough to strike both objects at the same time, they will be displayed as a single target on the screen. Beam width also affects the bearing accuracy, by elongating a target’s displayed image as the wider beam sweeps across it. This must be taken into account when taking bearings with radar. A narrow-beam antenna does a better job of focusing the available power, and the result is more effective radiated power aimed at the target.
The antenna should be mounted at a height that places it at least:
two feet above,
and four to five feet from,
the head of anyone on board.
Mounting the antenna more than about 22 feet above the water will not make a worthwhile contribution to maximum range operation, and can degrade the radar''s ability to show important close-in targets.
Placing a radar on an insulated backstay used as an SSB antenna will likely produce unsatisfactory results. Most radar set scanners must be connected to the vessel''s ground bus. A ground on the radar scanner will therefore place a ground on the backstay, unless the mount were specially insulated from the stay. The insertion of a ground at this point will make tuning the antenna difficult, if not impossible, and reduce the effectiveness of the antenna during transmission. In addition, the relatively high-voltage RF field surrounding the backstay during transmission may damage components in the radar scanner.
Gimbaled mounts can cause problems with some radar scanner connecting cables. The constant motion of the scanner, relative to the surface on which it is mounted, can fatigue the cable, which is not designed to withstand this type of service.
It is likely that the best overall results will be achieved by mounting the radar on a short mast at the stern of the boat. It is unnecessary to mount the scanner at any great elevation; in fact, too high a mounting height can create problems when trying to see close-in targets. Remember, a higher antenna heigh will increase your maximum range - but will also exacerbate the ill effects of pitch and roll.
I would mount the radar on a stern mast so that it clears the deck by about eight to ten feet. This will likely place the radar antenna about 11 to 14 feet above the water. At this height the radar horizon will be at least four miles distant. Targets at this same height above the water will be visible at about eight miles, with higher targets visible at longer ranges.
A note on interference:
For GPS to work properly, it is recommended to be positioned 12 inches above the radar dome (or open array), and have an unimpeded look skyward at the satellites, It is also important that the VHF and cellular antennas are mounted 12 inches or more away from the radar and the GPS, so as not to have three or four bands of [electronic] waves interfering with one another.
