SailNet Community - View Single Post - Temp Sending Unit on Heat Riser - how to test?
post #2 of Old 05-21-2009
tommays
tommays's Avatar
There is generally a sender that that changes Resistance to control the gauge and if you touch the CORRECT wire to the block the gauge should move
And a separate unit with a switch that would run the alarm at the temp that is to hot
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
