SailNet Community - View Single Post - Temp Sending Unit on Heat Riser - how to test?
post #3 of Old 05-22-2009
lshick
Send a message via Skype™ to lshick
There are two types of senders: those that drive a gauge, and those that drive an alarm. tommays is correct about the behavior of a sender that drives a gauge. In many cases, a sender that drives an alarm is mounted on the ground side of the alarm circuit; in case of an overheating situation, the switch inside the sender closes to complete the circuit to ground.
I have tested the alarm on my boat by touching the wire to ground, as you suggested.
Larry Shick
V42-148 "Moira"
lshick is offline
