SailNet Community - View Single Post - plywood-epoxy construction
post #2 of Old 02-15-2005
Jeff_H
Moderator
Jeff_H's Avatar
I think that you need to provide more detail because there are a number of contruction approaches that could loosely be called "plywood-epoxy" and they vary quite widely in their quality, and durability. Epoxy saturated cold molded plywood, in which individual veneers are laid up to create a hull that is in effect a single sheet of plywood can produce one of the strongest (for its weight), low maintenance, and most durable boat building techniques that there is. At the other extreme is a boat built from sheet plywood that is sealed with unreinforced epoxy resin, which is a pretty inexpensive way to build a boat but which is not all that strong or durable. There is an extremely wide range of variations in between.
Jeff_H is online now
