SailNet Community - View Single Post - Can anyone identify this track and slide?
post #3 of Old 05-23-2009
measure your track, compare it to makers that you can find, then buy your slides from them. Only the width, and thickness of the track itself is critical the upright/base doesn't matter really. Yours, with that recessed center, means that you'd want to go with a screw type, not spring loaded.
Can you measure the slide itself?
On one of my boats there was a box of parts, and I ended up with a couple slides that don't fit anything I have. They're wide enough, but made for a thicker track.
Here are the dims for schaefer tracks, which may allow you to match yours up and determine if the slides will work:
APS - Schaefer T-Track Eye Slide Cars
merc2dogs is offline
