SailNet Community - View Single Post - Filling 3/8" hole in hull. Boat in the water.
post #5 of Old 05-24-2009
pdqaltair
pdqaltair's Avatar
If your not on the boat 24/7, I would suggest a bolt.
~ 5/16" with a washer gasketed with butyl tape. Push it in from outside and put a nut on it. If you use the nut to push the plug inside, you'll hardly leak a drop. This would probably be safe for a season. I have seen plugs like this serve in 500,000 chemical storage tanks for years... which is a little frightening (the gasket material varies with the chemical).
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
