SailNet Community - View Single Post - Filling 3/8" hole in hull. Boat in the water.
post #6 of Old 05-24-2009
JimsCAL
JimsCAL's Avatar
It's really going to be difficult to do a proper repair in the water. Maybe if you can apply some sort of a seal from the outside, you can do something, but it is going to be difficult to get the area clean and dry. As roline noted above, you need to bevel the edges and lay in layers of glass fabric to build up the thickness. Just applying epoxy to plug the existing hole is not the way to go. I would plan on hauling soon to fix this right.
JimsCAL is offline
