I'd highly recommend you read this
POST to help you get the most out of sailnet. Your current OP is a bit on the vague side and not likely to be getting any good answers. It would really help if you said what dielectric silicone you were specifically referring to. IIRC, most silicone is dielectric, since it is a lousy conductor... are you talking about a dielectric silicone-based grease, a sealant, self-fusing tape???
Also, why do you need to splice your VHF wire. Most of the time, splicing it, unless there is a specific need for doing so, is a bad idea, as it introduces a fair bit of signal loss. A dielectric grease won't help with signal loss, but may help in preventing the connectors from corroding.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
