Swimnfit—
Glad to help... good luck and keep us posted.
StewSam—
corrosion is clearly the greatest problem affecting steel boats. However, there are some other issues, and many of them won't be readily diagnosed or recognized by the average boater. The type of steel used is often a huge factor in the longevity and durability of a steel boat, as is the preparation and surface treatment of the steel. Neither of these are something that you can tell by just looking at the boat.
There are also issues of balance and performance with steel boats that are less obvious. If the boat wasn't drawn as a steel boat to begin with, there may be some serious compromises to the boat's performance and stability.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
