SailNet Community - View Single Post - Trucking a PSC 34
Old 05-27-2009
jrd22's Avatar
jrd22 jrd22 is offline
Courtney the Dancer
With a beam of 10' you will need overwidth permits in each state you pass through. Although the displacement is only about 13-14000lbs the weight is going to be up fairly high so you will need a heavily built trailer to do the job safely. I've hauled a lot of equipment with everything from pickups to the largest semi's and you should not underestimate this trip you are considering. Anything less than a class 8 truck with semi trailer and you are asking for trouble IMHO. Dudley is a reputable boat hauler and I personally used Load a Boat to transport our 40' from San Diego to Anacortes and they did an excellent job. Good luck, maybe we'll see you in Desolation this summer.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
