SailNet Community - View Single Post - Crimping versus Soldering
post #155 of Old 05-27-2009
thekeip
Mitiemp...
Anyone who's soldered "radio connections" of any sort knows what is meant when "it looks right"...bright, shiny, and the solder permeated into the joint. You don't have to cut the joint apart to examine it.
You just can't look at a crimp and know if it's good or not.
I quite often run into conductors that need to be spliced or terminated...older RG-8, old non tinned multidstrand, or many applications where replacing a cable would be impractical, or where the conductor can't be replaced at all
Howard keiper
Berkeley
thekeip is offline
