SailNet Community - View Single Post - serious fiberglass repair- help
post #2 of Old 05-27-2009
sailingdog
Dave—
You will need to get fiberglass cloth and epoxy. This is definitely a structural repair and will need the strength of epoxy resin—especially since the repair will be depending on the secondary (or adhesive) bonding characteristics of the resin for its connection to the boat.
The real issue is how you are going to go about getting the repair to be the correct shape and making sure the laminate is thick enough to support the loads that it will be required to support—like those imposed by the forestay.
I would recommend using heavy cloth to build up the layers fairly quickly.
I would recommend getting the epoxy from Progressive Epoxy Polymers. I would recommend getting the cloth from Fiberglasssite.com.
Is there another Nicholson 31 that you can make a mold of the bow from?
sailingdog is offline
