What HS is suggesting is the typical installation I usually recommend. Two pumps. The first is a maintenance pump and is smaller capacity, with a smaller hose, and has the float switch in the very bottom of the bilge. The second is a larger dewatering pump and has its float switch an inch or two higher.
