SailNet Community - View Single Post - Broken Mast
Thread: Broken Mast
post #1 of Old 05-30-2009 Thread Starter
Broken Mast
Hi All,
Last week while sailing the port side chain plate let go on my O'Day 22. The bottom of the mast ended up getting bent about 2 -3 inches up from the base. I am not sure what to do. My first inclination is to cut it past the bad section (about 4 - 5 inches from the base) and make new stays and shrouds to fit the new length. Does anyone see a problem with doing this? (I have attached some pics of the mast)
Also, the chain plate was a deck mounted one. I need to put a new one in. I plan on replacing the starboard one too. I am thinking I will replace them with another deck mounted set. Would it be better to use a regular chain plate that bolts to the side of the hull?
Thanks in advance for your help and advice,
elrond11 is offline
