Old 05-30-2009
windward54 windward54 is offline
windward54 is on a distinguished road
I have a Freedom 30 inverter/charger and a Honda EU2000 generator. I have to change the power share setting on the control panel to 20 amps from the normal 30 amp shorepower setting before I try to charge up the boat. If I don't, I have the same problem you have.
The charger is going to pull as much power as it can to get the job done. The ac output of the EU1000 can't keep up and overloads. I'm not sure if you have a power setting on your charger, but if you have one, set it at 10 amps and you would be ok.
