You don't kill the motor by pulling out the choke do you?
Do you forget to take off the choke after starting?
Does this motor have an oil injection tank?
Change to a motorcycle 2 stroke oil and use the same mixing ratio.
Check that you are using the correct heat range plug.
I DON'T RECCOMMEND THIS BUT MANNY DO----
when stopping the motor shut off the fuel first and let the motor die by running out of gas.
I would be very wary of this shop----
Originally Posted by mountforever
hey everyone...well
i called a local outboard repair shop here and they said something about the seals in the chamber possibly being loose and getting oil to the spark plug. but at $140 an hour i'm hesitent to take it in for repairs.
any help would be appreciated.
