Mix the fuel at no more than 50 to one, and use NO fuel additives. Fuel additives contain ethanol, which combines with the oil and emulsifies it with any moisture in your fuel, there is always some, and gumms up the works. Also don't use ethanol mixed fuel, gasohol or such, only pure gasoline. New clean fuel, no additives and a quality 2cycle oil at no richer than 50 to one. If you still have a problem, you have a problem.
Reason: additional info.
