The hardware is likely bronze, not brass. Brass isn't used much on boats, since it doesn't hold up to salt water exposure all that well. It would help if you said what kind of boat you had, since it may be a stock part on that boat, with a known source... I'd highly recommend you read this
POST to help you get the most out of sailnet.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
