Yes, I know it's linear - that's why I specified the 6amps continuous.
BUT, YES I DID FORGET the Outback display is showing amps at ~115 volts. so you are right, my actual usage is the 5 amps from the DC meter plus the 10 amps from the AC. So I'm drawing 15 amps total (big difference) - thanks for catching that.
Series parallel always throws me. You're right, 675AH @ 12VDC at the 20-hour rate which at 50% would bring me down to 337capacity / 15use = 22 .5 hrs theoretically.
This helps A LOT - THANKS.
