SailNet Community - View Single Post - How heavy is too heavy II ?
Old 03-07-2005
PCP PCP is offline
PCP is on a distinguished road
Silmaril, I believe older boats, even old racing boats, are normally "less radical" than most of modern boats and have a smoother sea movement.
They have a less flat hull and have more ballast, depending less on form stability.
I own a modern 36 footer ( length overall 37.4 ft) that is not even a racer, (only a fast cruiser) and it displaces only 10,361 lbs for a ballast of 2,954lbs. This displacement in a flat hull and 721 sq feet of sail makes a fast easy planning boat, but also (I believe) a less comfortable boat than yours in what regards sea motion.
Of course, this light displacement, which is what I want for the use that I give to the boat (costal, with some short ocean passages, like Madeira and Canary Islands), makes this boat not an ideal boat for Oceangoing, I mean go anywhere boat, even if it is U.E. classified as a class A boat (oceangoing).
You can have a 36ft much better suited for ocean travel, but it would be a lot heavier and a lot slower.
I am looking for the right type of boat to go anywhere as fast as possible, safely and with some comfort . I will only need it in 5 years or so, when I will have more time to travel.
I don''t want a slow boat, so I agree with you that the right size is between 40 and 45 (to handle the boat alone) and I don''t want a difficult boat to handle because I am not going younger and I want to sail and travel till an old age.
The balance will be between size, weight and price, knowing that a smaller boat will have to be proportionally heavier and a bigger boat will have a more costly maintenance, higher marina prices, and it will be a lot more difficult to handle in small marinas.
Everything considered (including price) I will look for a boat between 38 and 43 ft.
I know what I don''t want, but I still don''t know what will be the better choice.
I want a modern boat that makes full use of technology and design advances.
Lots of different choices out there.
The Vailant 42 is a great boat (and very expensive, too expensive to me anyway) but I think that there are other boats that offer the same qualities with a better price and performance.
