SailNet Community - View Single Post - Butyl Tape - Did I find the right stuff?
post #6 of Old 06-05-2009
pdqaltair
pdqaltair's Avatar
No tape. Trim with a knife a few minutes after tightening.
Originally Posted by josrulz View Post
Sweet. I wanted some stuff that was thinner, so I'll probably have a lot of "ooz" with this stuff when I tighten down hardware, but I think it'll work just fine. I'll use lots of painters tape.
As for genoa tracks, would you use this on the bolts too? I was figuring I'd wrap some around the bolts near the head before tightening everything down. Is this what I should use, or should I use a different sealant at the tops of the bolts?
Thanks!
-J
Only light pressure is needed. The tape will just give it something to stick too, in my opinion.
Yeah, same stuff under the bolts.
My favorite uses are stanchion bases and running lights. Consider something else (3M 4200?) where adhesive is needed.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
