SailNet Community - View Single Post - Yanmar raw water cooling problem
post #2 of Old 06-07-2009
Mipcar
An Aussie Sailor
Mipcar's Avatar
Do you have a seacock to close off the intake when the engine is not running?
If not then I'd suggest your making the pump re-prime itself every time you start the motor.
Strongly recommend you fit a strainer, easier to clean gunk from that then having to disassmble the pump.
Also running the pump dry every time when you start will shorten the life of the impeller.
Mychael
Mipcar is offline
