SailNet Community - View Single Post - Good idea or not: Downhaul for hank-on jib
Old 06-08-2009
SailKing1's Avatar
SailKing1 SailKing1 is offline
SailKing1 is on a distinguished road
JG, I had a down haul on my I26 and it worked great. I spent a lot of time single handing and did not want to climb on deck to stow the jib.
I set mine up just as you had outlined.
You will need netting to keep the sail on deck. By sure and run the stantion block out of toe stub area and keep down haul line tight. A kink from rough seas will prevent it's use. I found out the hard way.
Also don't run the down haul throu the hanks, it will snag and cause you to cuss alot.
