Bristol 32 Centerboard Cable Tube
I recently discovered a small drip coming from the vicinity of the centerboard cable tube where it runs next to the engine. After carefully removing several layers of epoxy putty (about 1/2 a pound) and duct tape I finally reached the original fiberglass tube. For reasons unknown, the tube appears to have been purposely cut by the POs and then patched with with epoxy putty. Over the years the layers of epoxy putty formed a mass attached to the engine mount box.
Here's where I need help. Should the centerboard cable tube be attached to the engine mount box or should it be independent? Could have, would have, should have taken pictures.
Thanks.
