Our 43 has all the instruments connected to the same switch. If I want the
E120 off I just power it down with it's own power switch. You should be able to shut down the Autopilot as well.
Can you explain what you mean by the voltage not being accurate. Are you referring to the display on the switch panel? If so what is the problem?
Mike
