Did work on it last weekend (long and painful). Gosh, electrical wiring on Benes are snakenests. Mike, my system was wired everything bonded to E120, except for Autopilot. I mean, I had to power on E120, on its own switch, in order to have ST60s on. A draw would show beter, but will try to explain. Dealer got 12V power from E120 Seatalk to power ST60s, not directly from boat 12V power. When I turn on "Navigation" switch at panel, it powers AP and E120 only. The GRAPHIC ST60 display has ENVIRON page to read 12V system, from cockpit, and old wiring simply didn't work as E120 puts a regulated 12V on SeaTalk power (navtable panel 12V meter can be adjusted). This is exactly same schema used on AP, to avoid AP powered by tiny SeaTalk power cable. Another mistake, they did run 6mm2 wire cable, wich I replaced by 16mm2 (that explain the pain on my hands). Although Raymarine swear E120 works from 10.7-32V, mine just start to blink and sometimes reset, if voltage measured on instrument fall below 11.9V, specially if display is in bright mode or radar is on. Now, when I turn "Navigation" switch on, it powers AP and ST60 instruments regardless E120 is on or off. I still wanted to power AP independently, but will require panel midification, so will wait a bit more ....
Nave Rara
Beneteau Oceanis 43 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
