SailNet Community - View Single Post - Irwin Citation 34
Old 06-10-2009
KK5RX KK5RX is offline
KK5RX is on a distinguished road
Irwin Citation 34
I am considering a 1985 Citation 34 Shoal draft (4-ft 3-in) model.
One boat review in particular is causing me problems and has me questioning if its even worthwhile going ahead with the expense of survey & haul out is the review by Jack Hornor in the November 2000 issue of Spinsheets - Chesapeake Bay Sailing
"...the decks, on the other hand, are a different story. The deck and hull are joined on an inward flange with sheet metal screws through an extruded aluminum toe rail. There have been more than a few problems with the fit of the deck-to-hull joint, and leaks are a common problem that are difficult and expensive to repair due to inaccessibility.
Although some of the deck hardware is attached with nuts, bolts and washers, the lifeline stanchions, bow and stern rails are fastened with screws. This is not only unsafe, but loosening fittings allow water to penetrate the balsa core decks leading to very expensive repairs. Leaks around poorly fit windows and ports are also common but are more easily remedied."
The boat looks generally clean with no obvious signs of water or water damage.
However, this review is causing considerable angst.
What is the conventional wisdom on the Citation --- and the article by Jack Hornor?
tks
Rick
