SailNet Community - View Single Post - Spinnaker Handling: 180 Turn - beam reach to beam reach?
post #5 of Old 06-12-2009
Hudsonian
Arrange the jib along starboard rail making sure that the port jib sheet goes over the spinnaker pole and lift bridle forward of the pole lift; set the jib; drop the chute to leeward (probably under the foot of the jib and into the forward hatch leaving the sheet, guy, and halyard attached); drop the pole to the deck leaving the pole lift and down haul attached; take the slack in the pole lift aft and tie it to the base of the mast; harden up; tack; bear off; snap the new guy into the forward end of the pole; untie the pole lift from the base of the mast; raise the pole to the proper position; open the forward hatch; cheat the tack forward to pole; and hoist the spinnaker.
Hudsonian is offline
