SailNet Community - View Single Post - Slideing gooseneck vs cunningham
post #9 of Old 06-17-2009
sailingdog
Depends on the boat. But many have a mast step that is essentially a plate that the mast sits on. For instance, this is the mast step on my boat.
It is basically a three-sided box that the mast slides into. It has plates attached so I can use blocks to lead lines aft, and has two holes for safety pins that prevent the mast base from moving forwards.
On a lot of boats, you could mount that plate where the mast sits on the cabintop by loosening the shrouds and stays a couple turns...since it is only 1/16" thick or so.
Originally Posted by jarcher View Post
SD, I have never seen an unstepped macs, so forgiv this dumb question, but does the mast somehow sit on that plate? The impression I had is that the mast step is like a shoe that sticks up, and the mast site on top of it, and the step comes up into the mast a bit to prevent it from sliding around on the deck. But I could be wrong, as I have never seen how it works.
sailingdog is offline
