It doesn't sound like your surveyor was very competent. Coming to a survey without a properly working moisture meter, if that is a tool he normally uses strikes me as a bit incompetent... not carrying an extra battery for the meter is just stupid on his part. I would be leery of relying on his survey or advice.
I'd also recommend you read the
Boat Inspection Trip Tips thread I started, as it will help you determine a lot about the boat, and help you decide whether a survey is warranted or not—saving the cost of a survey on boats that are not worth considering further.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
