SailNet Community - View Single Post - Help w/ proper name ...
post #5 of Old 06-21-2009 Thread Starter
wind_magic
Just curious, what are you planning on using it for. One that can support 1000 lbs. of weight safely is going to be relatively thick and heavy. If it is going to be supporting something overhead, you'd want a fairly significant safety factor in calculating the SWL.
Dog, what I want to do in the abstract is to have a load that has two rings on it, one on either side, and to lift that load with ropes on either end pulling horizontally so that the load is suspended in the air and is between two ropes as if it was suspended over a river with the ropes tied at either shore.
I'm starting to think that screw links like the ones that climbers use might be better able to hold a load instead of something round like a metal ring.
What are you pretending not to know ?
Please support my
wind_magic is offline
