SailNet Community - View Single Post - Packing a stuffing box
post #5 of Old 06-21-2009
SEMIJim
Originally Posted by johnseattle View Post
... I'm doing the job afloat and want to work as quick as I can.
Get a bicycle inner tube, cut it open and use it to "bandage-up" the shaft tube side of the stuffing box when you back the nut off to change the material. You should be able to all-but-stop water incursion. The other trick is silly putty in a baggie. Roll silly putty out, put in a baggie, stuff it into the shaft tube side of the stuffing box once the nut's backed off. (Note: The baggie is very important.)
Jim
SEMIJim is offline
