SailNet Community - View Single Post - Help w/ proper name ...
post #9 of Old 06-21-2009
sailingdog
Solid welded links are probably stronger than screw links, if less convenient. I'd agree with Sway that holding a load up by two essentially horizontal lines is not a wise thing and quite dangerous. The forces involved are quite significant and unless you're really aware of them, you're going to get someone killed. His point about the loads being enormously magnified by the lines being so close to horizontal is one you have to pay attention to.
This is kind of why I was wondering what your purpose for the rings was.
Just for yucks and giggles, take some small stuff, say 1/8" rope and try lifting a 50 lb. weight so that the two cords are horizontal as you've indicated you want to do. I know a 1/8" rope will hold 50 lbs. pretty easily, since the stuff I use has a breaking load of almost 450 lbs. I bet the rope breaks before you can support the 50 lb. weight with the lines almost horizontal.
Originally Posted by wind_magic View Post
Dog, what I want to do in the abstract is to have a load that has two rings on it, one on either side, and to lift that load with ropes on either end pulling horizontally so that the load is suspended in the air and is between two ropes as if it was suspended over a river with the ropes tied at either shore.
I'm starting to think that screw links like the ones that climbers use might be better able to hold a load instead of something round like a metal ring.
sailingdog is offline
