SailNet Community - View Single Post - Crew assignments
Old 06-22-2009
jarcher's Avatar
jarcher jarcher is offline
jarcher is on a distinguished road
Thanks everyone, a few comments and questions.
First, I could probably squeeze three people in the cockpit all on the same side, but I would be all the way aft, grabbing the tiller about at the rudder post. I don't think that would work, although next time I am down there I'll have a look.
Since those pictures were taken, I have added a Battlestick tiller extension, because its impossible to see anything from the cockpit. I have to sit up where the winches are mounted.
The traveler is just a few inches aft of the companion way. In fact the main sheet trimmer could do his job from inside the companion way, and I have considered that. If I run the outhaul and cunningham lines aft then everything that controls the main would actually be completely accessible from inside the companion way. The main is also completely visible too. Not that this is a great idea, as the footing there is not great (standing on narrow steps) and then he could not reach the jib sheets.
I was surprised to see it suggested that the job trimmer sit to windward. I know we want weight to windward to flatten the boat, but its a half ton boat. I was thinking the jib trimmer should stay to leeward, where the entire sail is visible and he can reach the winch, to keep it in trim constantly. Then the skipper and main trimmer could fit on the windward side.
As I type this, it occurs to me that perhaps the two cockpit crew members should just stay put, and change jobs? Whoever is on the lee side can be the job trimmer, the windward guy the main trimmer. Then they switch on a tack. Any reason that would not work (other then they both need to know both jobs)?
Also, someone mentioned that the lazy winch is loaded when we prepare to tack. I was in the habit of loading the windward winch as soon as the tack is complete, so we could quickly put about if necessary. Is that bad?
Thanks...
