SailNet Community - View Single Post - Crew assignments
  #11 (permalink)
Old 06-22-2009
DrB DrB is offline
DrB is on a distinguished road
Loading the Lazy Sheet
The reason why you don't want to load the lazy sheets up before you actual get ready to tack is if you need to quickly blow the jib for say a duck or to spill off wind in case of a super gust. Having the lazy sheet loaded up may not let jib/genny blow out. I know people do it all the time and I do it often in very light wind conditions, but if there is any breeze, I don't.
If you must load up the lazy sheet, put only one wrap on it, and not in the ST jaws.
As far as the jib trimmer sitting to windward, if you're close hauled, the jib is trimmed for close hauled sailing and the helm drives the boat to the tell tells. The trimmer shouldn't be trimming the jib too much. It's better to have the weight high, than have the weight low waiting for the possible occasional tweak trim. When I trim the main on a J105, the jib trimmer leans windward of the cockpit centerline against the companionway or just sits foward of me towards the windward rail depending on the heel angle. The primaries on the J-105 are on the cabin top.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
