SailNet Community - View Single Post - I need a reality check, please
post #3 of Old 06-23-2009
sailingdog
Originally Posted by OhioTom View Post
Hi,
I have a project boat and would like a reality check on my plan from those with experience.
I bought a 1976 Soverel 26 on a whim eight years ago. I reglassed and painted the hull before I moved, started having children, and forgot about her. The boat has been sitting, neglected, at my parents' for the past eight years. My children are now in school, my wife is back to work, and I now live at a house with a very large concrete driveway/parking lot in which to work (the previous owner had a huge RV). I'll be moving the boat here on July 1st.
My goal is to get her in the water May 1st, 2011.
The boat's current condition: The hull is excellent. The deck is the biggest problem. It has two large areas which will need recored. All the deck hardware needs to be re-mounted (properly). The inboard diesel is shot. There is a ton of deck hardware in good condition - it seems to be state of the art 1990's racing gear. Honestly, I could probably strip her and sell off the deck hardware for a good profit. The standing rigging is in decent condition and the running rigging is serviceable - sort of. The sails are good. I have seven, all 1990's era kevlar racing sails. The main is in good shape, I have 2 #1 genoa's - one is about 50%, the other looks unused. The #2, #3, and #4 all look new. The electrical system is junk and needs completely redone.
My plan:
2009: - Remove the diesel, re-core the deck, re-paint the deck, re-mount the deck hardware.
Recoring the deck is relatively easy to do, especially if you work from the top down, rather than trying to preserve the exterior and working from the bottom up. Doing this with Epoxy resin is relatively easy and straight forward.
If you're going to remove the in-board and not replace it, you'll probably want to remove and close off the through-hulls that will no longer be necessary.
You'll also want to make sure that the outboard motor mounting system is decently supported to handle the forces involved.
2010: - Finish re-mounting deck hardware (if not done), re-paint topsides, bottom paint, replace electrical system (I'll convert to an outboard and just have one battery with shore power recharge for minimal electrics).
2011: - Put her in the water, step the mast, replace running rigging, install outboard
Don't skimp on the electrical wiring materials—use marine grade wiring and adhesive-lined heat shrink crimp terminals.
Also, you might want to consider adding some passive electrical recharging capability, like a solar panel. Having to rely on shore power really limits your ability to cruise, especially if you're outboard powered, since an in-board engine has a much wider choice of charging options. I'd recommend you read the primer I've written on using Solar Power On Boats.
I've never rehabbed a boat but I've rehabbed several houses over the past few years, so I'm pretty good with project planning and knowing what I can accomplish. The biggest single ticket item will be the outboard as I'll probably spring for a new one (thinking Suzuki).
I'm not looking to restore but to renovate. I want to do what I need (and little more) to get her on the water. I'll deal with "nice to have" later. My budget is pretty minimal until 2011 and then I'll have a significant jump in disposable income (allowing the new outboard, dockage, rigging, etc)
Those who have done similar, does my plan look feasible enough? Any tips or insights would be appreciated.
Thanks.
Just remember, overall, the materials costs are going to be relatively small, as a percentage of what you actually spend, in time and money, and skimping on the materials is going to lead to an inferior end-result, so spend the small amount that it will cost to get the right materials.
sailingdog is offline
