Prop Drag :folder vs Max
The Max-prop has a touch more drag than the Martec but the difference is small, especially as compared to a fixed prop. I don''t agree the Max-prop is far more efficient in normal motoring. Max-prop blades are flat, with no twist or cup. Both tests I have seen and discussions with people who have them confirm the Max-prop is not all that efficient in forward. People who find them so are usually responding to the ability to adjust the pitch. A properly pitched Max-prop will be better than another type that might be more efficient but is not pitched right.
The Martec is not the greatest in reverse but it can do the job. How much power do you need to back out of a slip? They aren''t that bad in forward. Years ago I raced against a friend with a sistership. We both had Yanmar 2QM15''s swinging 14x14 props. I had a Martec, he had a 2 blade fixed. We were way faster under sail, but what got him was one day motoring alongside to a race start we tried setting throttles to the same rpm. At each throttle setting we would slowly walk away, including flat out. He bought a Martec after that. We learned a two-bladed fixed prop has its own compromises. Blade area is reduced on some models to lessen drag.
I''d only get a Max-prop if power in reverse was the highest priority, they are unmatched for that.
