SailNet Community - View Single Post - spinnaker w/o a topping lift for the pole?
Old 06-25-2009
GeorgeB GeorgeB is online now
GeorgeB is on a distinguished road
You need that topping lift to both hold the weight of the pole and to stabilize it as a spar. You need to be able to adjust the tip end for variations in wind speed. That is how you keep the clews level. Without the ability to stabilize the pole, you will not be able to effectively “choke down” the sail if the wind picks up too much. You will not be able to gybe the boat. The topping lift has to support the weight of the pole in both the dip-pole and the end-for-end gybes. Once you release the halyard for the douse, the pole tip will come crashing down to the forepeak or pulpit. You could go without a topping lift – it will be messy and you do run a real risk of seriously injuring your bowman. I suggest he wear a climbing helmet and you increase your insurance coverage.
