SailNet Community - View Single Post - spinnaker w/o a topping lift for the pole?
Old 06-26-2009
Faster Faster is online now
It's not that difficult to rig a pole lift - esp if you're happy to have it all external. It could be mounted as low on the mast as the spreader height. In fact if you don't want to drill holes you could lash a block to the spreader roots.
Flying the spinnaker in light air will be virtually impossible without a easily workable pole lift (adjustable from the cockpit is best). In heavier air the sail will support the pole, but as suggested above gybing cleanly will be much more difficult.
1984 Fast/Nicholson 345
