SailNet Community - View Single Post - Chainplate rebedding with mast up
post #6 of Old 06-26-2009
gtod25
Have you tried Sikaflex 291?
All-purpose, polyurethane adhesive and sealant for use above or below the waterline. Elastic, sandable/paintable.
  • Formulation: One-part polyurethane adhesive/sealant
  • Recommended Usage: Humid climates, high temp., long assembly time; sealing wood hull seams, thru-hulls, bedding deck hardware
  • Material Incompatibilities: Acrylic plastics (ABS, Lexan)
  • Adhesion Rating: Tensile: 200 psi; elongation: 700%
  • Cure Time: Tack free: 3 to 5 hrs; complete cure: 3 to 14 days
My project Click here
gtod25 is offline
