SailNet Community - View Single Post - headstay tension
post #7 of Old 06-26-2009
knothead
KH, not all the B&R rigs from Hunter were backstay-less. The early masthead versions had normal backstays, and even up to the mid 90s the fracs had a conventional backstay too.
It does sound like the OPs rig is ridiculously loose - and he does indeed need the services of a rigger as you suggest.
Yeah, I quit reading before I got to the part where he mentioned the backstay. Some of the older hunters had a traditional rig and you're right, most of the older B&R's had backstays too.
I was mostly concerned about the fact that he doesn't know how to add a wrap or two of furling line on the drum or a wrap or two of the sheets around the sail and the fact that he is getting halyard wrap with a Pro-Furl. The Wrap Stop should prevent that from happening as long as it's installed correctly and the halyard is tensioned.
It really sounds like he could use some instruction.
knothead is offline
