SailNet Community - View Single Post - Thruhull/Seacock Removal
post #3 of Old 04-10-2005
RichH
RichH's Avatar
After 18 years in service the throughhull has probably lost quite a bit of its zinc content. Simply take a face grinder and grind away from the outside until you can push the remaining stub through the hole. Just be careful not to overheat the through-hull by excess grinding so that you dont thermally stress the fiberglass. Otherwise, if you want save and reinstall, use an ''extension'' on your pipe wrench as a ''persuader" - sometimes packing the inside of the bore with dry ice will help.
RichH is offline
