Originally Posted by JohnMaschek
KNOTHEAD - The BF3-1K certainly looks like the culprit. Maybe all the pieces are there and just missing the retaining bolt. Could I be that lucky??
John Maschek
If the upper shroud had separated from the spreader end, then the speader tip must have not been secured to the spreader by a screw through the end of the tip/spreader. If you cannot see the parts of the spreader tip hanging around the uppers where it passes thru the lower spreader, then I would expect the tip opened up and the two parts seperated and went into the drink. and will need to be replaced. Was there a spreader boot over them...what happened to that?
If it appears the parts are missing, you should order a replacement to have in hand when you go up the mast so you don't have to repeat the trip. get new spreader boots if needed, use a good quality rigging tape.
