Electrical Grounding for an Encapsulated Keel?
So a Formosa 41 has an encapsulated keel. Like everything else there's pros and cos. I don't worry about keel bolts corroding or working loose, but I do wonder how I am going to create a ground.
I've followed the ground/repel lightning debate for a while but it's all academic if I can't find an efficient and large ground for my boat. The proponents of grounding for lightning safety all tell you to ground to a keel bolt. That's great, except I don't have any. Grounding to my prop shaft just seems like a bad idea intuitively, and my through-hulls aren't big enough.
Another issue is Ham/SSB which I plan to add at some point. How do I create an effective ground plane for the radio with a hull like mine? I hear that some people run a large copper strip along the outside of the hull which is (I guess) through-bolted. Would that work for lightning too?
What does everyone else with encapsulated keels do for lightning and SSB grounding?
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
