SailNet Community - View Single Post - Recommend an Ablative bottom paint for FL???
post #4 of Old 07-01-2009
jason3317
Micron 66 is a proven multi-season anti-fouling. If you are going to stay in for extended periods of time, you need to consider applying a couple of extra coats over the standard 2 coats, plus additional 'stripe' coats on the water line and leading/trailing edges of the foils.
Since you are blasting, I would recommend using an initial flag coat of a different color than the top coats of anti-fouling to signal when it's time to paint again.
jason3317 is offline
