SailNet Community - View Single Post - Leaking water pump.
post #6 of Old 07-01-2009 Thread Starter
L124C
L124C's Avatar
Originally Posted by pfatyol View Post
The shaft seal is bad, and needs to be replaced. I had it happen to mine a couple of years ago, replaced both bearings and the seal, very easy to do. I have 2GMF. Mine was leaking when the motor was running but it was the exact same spot.
Good luck,
Pat
Thanks everybody! I'm sure mine is leaking while it's running also, I just can't hear it. The Yanmar manual doesn't give me much. I assume when I pull it apart it will be fairly self explanatory? Thanks again!
L124C is offline
