  #18 (permalink)
Old 07-02-2009
chris_gee chris_gee is offline
chris_gee is on a distinguished road
It seems to me that several posters have missed the point. The wind is turning the bow to stb and the prop is turning the stern to point and therefore the bow to stb. You can't afford to swing to stb too soon or you hit the other boat. You can walk it out at least partway, but even getting some way on so you can be in neutral will likely mean you cannot turn the bow to port, and will probably go straight. When you go into forward agin it is going to be easier or have a tendency for the bow to go to stb, so you still have to back out, or do a 270 deg turn in stages because I doubt you can do a 180 on the first pass given the usual lack of space between piers.
Using a midline to the rear cleat you can pivot so it turns 90 deg quickly then let the wind blow the bow around with a bit of forward then reverse to spin her through the first 180 or so clockwise then it starts getting easier to turn going forward. I dont think it is all that easy to start but two help.
You don't need much boat speed in reverse but how quickly the boat stops depends on the prop. I found a 3 blade much better. Don't be afraid to use the tiller well over and don't worry about having to back and fill sometimes until you get it right.
