SailNet Community - View Single Post - Engine vibration between 1100-1200 RPM - Normal?
Old 07-02-2009
zAr zAr is offline
zAr is on a distinguished road
Originally Posted by RichH View Post
What's the 'clearance' status of the cutless bearing?
I gave the prop and shaft a good tug and turn and there was no play at all with the shaft in the cutlass bearing, the prop turns fine - didn't seem to be unbalanced.
Regarding your suggestion of going to this RPM range in forward and reverse, what's your thinking behind this? If the vibration continues then it's probably a misaligned shaft?
