SailNet Community - View Single Post - Engine vibration between 1100-1200 RPM - Normal?
Old 07-03-2009
RichH's Avatar
RichH RichH is online now
RichH will become famous soon enough
Originally Posted by zAr View Post
I gave the prop and shaft a good tug and turn and there was no play at all with the shaft in the cutlass bearing, the prop turns fine - didn't seem to be unbalanced.
Regarding your suggestion of going to this RPM range in forward and reverse, what's your thinking behind this? If the vibration continues then it's probably a misaligned shaft?
Eliminates the transmission (thrust bearing, clutch / flex plate etc.) anomalies.
