I would strongly suspect that the lower pulley is connected to the crankshaft. Getting a reliable reading with an optical tach is not as easy as it first appears. Any difference in reflectivity can produce a "pulse" and through off the reading. Make sure the reflective tape is on a clear are of the pulley and move the sensor in and out until you get a steady reading.
